StevieFixes
- WSM2700HWW
- GE
- 1-5 years
I have 2 issues occurring with my unit that started at the same time.
1st issue:
As I began a second load of laundry, the drum filled with water as usual, I added soap and once it was full added the clothes so as not to overfill or unbalance.
But then when I closed the lid, cute washer did not begin to agitate.
I tried to turn the knob to spin, nothing.
Tried to restart, and end, the drum did not drain or move.
I let it sit for a while to see if it would eventually drain. It did not, however, when I moved it to rinse, it drained, began the rinse and then spin, and the lid locks as expected when spin begins.
2nd issue:
When it began to spin, it shook heavily, hitting the front plate over and over.
Troubleshooting:
When I took off the front panel - there are no obvious issues,
1st issue:
2nd issue:
Troubleshooting:
- Both of these issues occur with and without clothes in the drum.
- If set to wash, the time does not move without agitating
- In removing the agitator pieces within the drum, nothing appears to be broken, loose
- does not seem to be broken suspensions (perhaps a little springier than they once were)
- I can observe the lid lock mechanism take place when spin begins
- Belt moves, (only during spin of course)
- Drum does move a little more freely back and forth than it seems it should
