FIXED GE Stacked Washer/ Dryer GTUP240EM6WW Pausing randomly during agitate cycle.
Heratiki
North Myrtle Beach, SC
GTUP240EM6WW
During any agitation cycle the washer will pause (can be restarted) at random intervals. Control Board changed with new one. Water Pressure Switch changed and verified working via multimeter. Washer doesn’t have any issues with filling to different size loads (tested filling from Small to XLarge and Autosense)
Heratiki
Found the solution on my own. One of the wires feeding the fork support assembly was damaged (The fork that engages and disengages the shifter hub) within the protective jacket. This would cause the unit to fail out during agitation because it couldn't read its position I'm assuming.
Hope this can help someone in the future. I haven't figured out how to mark a post as FIXED yet so Jake if you're reading you can mark this one fixed.
Good find @Heratiki glad you fixed that damaged wire.(y)
