- GSS-PSW 22-27
I've had to replace both motherboard and evaporator fan motors on GE SXS's with both the plastic and metal liners on models without the inverters. It seem to be limited to 22-23-25-26-27 cubic foot models. Customers replacing the motherboard have noticed a burn spot on the resistors below the J2 connector. In this case replacing just the motherboard will only result in another failed motherboard. Customers may have noticed freezer fan noise or excessive moisture in the freezer resulting in ice forming on the housing or blade before the motherboard failure.
Other symptoms were thawing and re-freezing in the freezer section. Most times this resulted in moisture getting inside the variable speed DC evaporator fan motor causing a short between (but not limited to) the white wire and the yellow wire on the fan motor. This is what is causing the "burned" mark on the motherboard. A 2002 GE Service bulletin addresses the fan noise and moisture issue (Attached).
On the main control board or motherboard diagram (Attached) notice the J2 connector is the DC fan motor outputs with the two large resistors directly below it. These are the burned resistors in the two pictures I've attached for easy identification. The burned resistor is not noticable 100% of the time. However, the fan motors showed water stains and/or rust around the motor shaft and bearing and fan motor bracket. I hope this was helpful information.
Motherboards and evaporator fan motors lookup
