GE Top Load Washer GTW680BSJ5WS - Drain spin issues
TomSr13
Hilton NY
GTW680BSJ5WS
Hello I have a GE top load washer model# GTW680BSJ5WS
In normal cycles… colors speed wash bulky items… the cycle doesn’t complete. It stops and does not rinse nor spin. On drain and spin it runs great. No error codes nothing. I ran a load on speed wash and watched the whole cycle.
The washer ran but the time remaining never left 10 minutes… the pump was running for about 5 minutes and all of the water drained. Suddenly the washer stopped and said it was done.
I have pulled the pumps and they are not clogged. I have taken the control panel off and made sure everything was connected (did this twice as the 1st time I didn’t re connect the vacuum hose and had and H2O issue).
I have tried the reset thing with opening and closing the lid 6 times. I am at a loss. Any recommendations? Thank you very much. We foster 5 kiddos and we need this bad boy running!
Richardesalomon
I had the same problems with the same model, and it turned out to be a very easy fix. Try to find GE Service Bulletin HL01-17.
Good luck…
Rich
