GE Wall Dual Oven PVM9195DF1BB neither oven lights work.
FrustratedDude
PVM9195DF1BB
Opened upper oven door to place food inside, realized light did not come on. Opened bottom oven and that light failed to come on as well. Closed both oven doors and tried OVEN LIGHT on touch pad. Lights did not come on. Checked Sabbath special feature and it is turned off. Will be PITA to pull light assemblies to check voltage at socket or change halogen bulbs. Because both seemly went out at same time, I suspect a common power lead or control board issue. Suggestions? Thoughts? Thanks in advance. Jim
Ok got it!
Here's the service manual: https://drive.google.com/file/d/0Bz...=sharing&resourcekey=0-gQqthXxfuAz_6b49X5wSBQ
Page 51 is the lighting troubleshooting section to check the oven door switch.
Page 53 are the pinouts for the clock oven control board--->CN600 is for the lights.
Light circuit CN600-5 BK to CN600-7 BR should be approx. 18 ohms. Make sure you disconnect power before ohm testing.
Here's the clock oven control board for your model:
Here's the oven door light switch for your model:
Switch Spdt High Amp WB24T10147
