GE Wall Oven identification/ part number for repair
Mandymoore17
West hartford, CT 06107
I’m wondering if someone can help me identify what model this oven is. I need to repair the receptacle that the wire connects to and the baking element. I’ve attached pictures
It is probably model J C16W1WH.
This link is pertinent to your message. It is supplied by this message author.
LINK > GE Oven JC16W1WH Bake Element
I don't know what you mean by that. Can you post a photo of the part?
Mandymoore17
I don't know what you mean by [I need to repair the receptacle that the wire connects to ]
Thank you! The metal piece that attaches to the wire which then attaches to the element. The red side has it but I need one for the black side
Ah, the wire terminals. You can probably find crimp on wire terminals at a local hardware store or just do without and wrap the bare wire under the head of the screw and then tighten the screw down.
Be sure to trim the wires back to an unaffected portion before stripping. Burnt wiring won't connect well and you could end uo with the same problem again. It might be easier to do that repair from the rear? The wires might be too short to work on from inside the oven.
