BR10
- GFW148SSM0WW
- GE
- 1-5 years
GE front load washer
Wash cycle was stalled, door was locked. I cleared a coin out of the drain filter, and drained a little water. The door unlocked. Machine would not restart.
I put machine into Consumer Fault Code Mode. Several codes displayed : E2, E4, FA, FC1, FV
I put machine into Service Mode, Water on. Went through each mode. Cleared codes in T02. Test T04 showed all buttons beeped. Test T05 , No valve action.
Test T06 , No water fill. Test T07, Drain pump Not running. Test T10, No spin
I put machine in Demo mode. Door lock symbol turned on and off but door did Not lock.
I tested the resistance on the door lock coil , Good
Tried running wash cycle, control knob and lights seem to work, but timer only runs for one minute and then control turns off.
Tested for codes, No new codes appeared.
Question : Could the door lock cause this default ?
Is there another procedure to reset control board?
