- GFWR4805F0MC
- GE
- 6-10 years
With one exception, the washer seems to function normally until the rinse cycle, at which point the machine makes a rumbling sound for 30 seconds or so, then goes quiet, rumbles again after 10ish minutes, goes silent, then finally goes off after 10ish more minutes. During this time, "Pause" scrolls across the screen for 10ish minutes, then "Off" for 10ish minutes.
The exception I mentioned is at the Drain cycle prior to the Rinse cycle. The machine makes the rumbling sounds for a few seconds during this cycle.
The washer was manufactured 9/2014. Consumer Mode reports Codes 6, 8, and 14. I've referred to the service manual and tried the following with respect to each code:
8 - Pressure sensor
- Replace pressure sensor - done, no effect
- Replace IMC board - done, no effect
14 - Recirculation pump error
- Check drain pump and clean - done, no effect
- Check recirculation pump in service mode - haven't tried
6 - Dispenser motor and wiring
- Diverter motor and wiring - haven't tried
- UI board - haven't tried
Any suggestions for a sequence of what to try next?
Will
8 - Pressure sensor
Will
