GE washer GTW220ACK7WW makes a squeaking/creaking sound when spinning very slowly
trakk
florida
GTW220ACK7WW
GTW220ACK7WW washer is 15 months old. Now whenever it spins very slowly, such as when done spinning, or if you just turn the agitator by hand, it makes a squeaking/creaking sound. What do you think it is? Belt?
Yes, I'd first check the belt underneath the washer.
Here's the belt for your model:
trakk
florida
I've checked the belt and it's ok. However, the motor pulley was very greasy and it sprayed grease everywhere. Seeing that it's attached to the 1/3 motor, could the motor be bad or is it greased like that from the factory?
trakk
florida
Looking at the parts diagram I think it might be the platform retainer and bearing as the agitator is now loose as well.
