- GTW460ASJ2WW
- GE
- 1-5 years
A few days ago the original board in the washer burnt out, I decided to replace the board, and according to a parts list, I could replace the now burnt control board part no. WH22X35137, I installed the new board and the washer would only partially operate it would wash for maybe a minute before beginning to fill again, and it would also drain but not spin, I did some more research and found the board needed to be set with a new personality ID, after reading through a few other post and looking at the original tech manual.
I was under the impression since my washer was a GTW460___J2 the personality needed to be set as personality 6, however, the board does not show that option it will go thru 0-5 then skip to 9 and does not give an option to select personality 6, I did more research but was unable to find any additional info regarding this board's personality information that would fix my issue. While I did find a few other posts referencing WH22X35137 they also suggested personality 6 which hasn't worked out thus far
- CJ
- CJ
