GE Washer GTW460ASJ8WW Critical Flood Level By Pressure Error
qcbicycles
NC
GTW460ASJ8WW
GE GTW460ASJ8WW Washer wont spin but you can here the motor. Error code received is a 6 which is a Critical Flood Level by Pressure error. I see with some models you just replace the sensor/switch but the electronic panels are different on the GTW460ASJ8WW. Is this something the solution is to replace the circuit board (not really $$ feasible) or is there another thing to trouble shoot. I did remove the drain hose and checked the exit hole at the pump and there doesn't appear to be anything in there. Thanks for your help.
Here's the service manual for your model: https://drive.google.com/file/d/1FiXXV68WvPZ4ukyUXtY7PGIV2C8bpVkK/view?usp=sharing
Do what it says in this chart:
If nothing in that chart fixes it, you will need to replace the control board.
qcbicycles
NC
Thanks for all the info Jake. Is there an easy way to get the shell off of this model so I can check all the other things recommended? 3 sides are all one piece. I realize checking the tub is the next logical step.
I haven't worked on many of these GE washers, that are not popular in my area. The only one I had in my area was pebbles in the drain pump causing the drain pump impeller to seize.
You can easily access the drain pump from underneath the washer, you have to unplug the washer, disconnect the fill hoses and drain hose first of course to lay the washer on its side to work on it FROM the BOTTOM.
Look on page 52 of the service manual, it says you can remove the cabinet assembly, but you need TWO people to do it, due to bulkiness.
qcbicycles
NC
Thanks again for your responses. Makes sense and will give that a try before throwing in the towel.
Ok, sounds good, keep us posted.
