GE Washer GTW460ASJWW water level incorrect
grhine42
USA
GTW460ASJ2WW
I own a GTW460ASJ2WW and have found recently that it no longer fills to the proper water level. When I paused the washer to add a piece of clothing, the water level was low and the clothes were basically dry. I purchased the washer in July 2017 and have not had this problem before. When I put the washer on super size, bulky items, and press and hold the deep fill button for 3 sec the washer only fills with 6 inches of water when empty. I tested the pressure sensor with a voltmeter and it is working fine. The water is not siphoning out either. What else could be the issue?
grhine42
USA
Finally had some time to look at the washer and here are the error codes I received. Error 22 - out of balance, Error 7 - flood warning level, Error 14 - spin, Error 19 - UI state timeout, Error 26 - out of balance ended final spin, and Error 25 pressure sensor dropout.
