GE Washer GTW460BMM0WW Not completing is cycle Error Code #25
oli1995
Montréal Québec
GTW460BMM0WW
Good Morning, i got a GE Washing machine that is about 2.5 year old and 2 days ago my GF started a deep fill load with no clothes in it to wash the machine.. since its not completing a normal cycle, it stop at rince or spin not sure exactly. I tryed to reset the washer with the unplug replug after 1min then 6X lid opening closing, no success. Then i pull out the error code here what came out the first time:
#14 Lid lock Failure
#7 Max Fill Pressure exceeds 16.5" pressure port
#25 Pressure Sensor dropout
I wiped the code then try a cycle again, only the code #25 came back. i tried in diagnostic mode to see if the lid locked in a cycle no problem there. did a pressure sensor test all the 7 light came on inthe filling, look all good there...
now im not sure what to do or where the pressure sensor is located to test it with a multimeter..
thanks for the help!
Olivier.
Hi Olivier,
You may need to have GE Canada come out and see what's going on, Your model is a Canadian GE model, which we don't have any tech. data information on here in the USA.
