CathyAd
- GTW465ASN1WW
- GE
- 1-5 years
I am frustrated! The lid lock on my 14 month old washer started working intermittently so washer wasn't spinning during most cycles. I replaced it with the new improved lid lock assembly (including wiring harness) - the old switch was broken. Same issue with new lid lock working intermittently so I thought it was the control panel. Bought replacement control panel WH22X35137 (specified by GE on their website) from local authorized parts house. Installed it; however, I had one extra wiring harness plug and no corresponding slot on board - thought maybe something was no longer being used. The instructions say my washer is personality ID 18 so I set it to that.
Checked error codes and it said the temp sensor was missing - doing a little research, I found that the missing plug slot location was for that sensor. Ran the spin and agitate tests while I was in the test mode and the lid locked perfectly. However, in actual operation, the various machine cycles didn't work properly to completion other than drain/spin. Lid lock worked intermittently. So I take it back apart as I know the control board isn't correct and go back to the parts store who gives me control panel WH22X32357 which matches my old board exactly.
I installed new board and set the ID to 18 per the enclosed instructions. No error codes during test mode; however, I still have same issues with various cycles not working to completion other than drain and spin. And the washing machine seems to be much louder. Is the personality ID 18 really correct? Is there something else wrong? I appreciate any advice.
