FIXED GE Washer GTW465ASN1WW won't lock or spin
BrandyS
GTW465ASN1WW
I have replaced the lid lock switch. After going into the diagnostic system, it recognizes the lid switch. I keep getting the fault code, #23 Critical lid lock failure. The machine will not lock the lid and therefore will not spin. It drains and agitates. Tested the lid lock harness and it reads 77 between the red & yellow when the lid is closed and 0 when it is open. Hoping I don't have to replace the control board. Going on 3 weeks without a washer...any help would be appreciated!
Rick explains how to test it here to verify if that one you got is bad or not:
Read post #17 and post #21 of Ricks posts there.
If the lid switch is good, then you do have a bad control board.
BrandyS
I ended up having replace the control board, but that's cheaper than a new machine! Thanks for pointing me in the right direction!
Excellent, glad to hear the new control board fixed it.(y)
