GE Washer GTW485ASJ1WS Not spinning heavier loads
MrGibbs
Minneapolis
GTW485ASJ1WS
GE GTW485ASJWS top load washer that is about 6 years old gets stuck in spin cycle with larger loads and doesn’t fully spin water out of load. Usually have to end up manually running spin/drain cycle to get it to complete.
Seems to work ok with smaller loads.
I’ve adjusted the leveling feet and that seemed to help some and machine doesn’t bounce around.
Any ideas?
Added complete model number
Your missing a digit in your model number after the "J" before the "W". Read it from the tag on your machine, which should be located under the lid.
Here's the service manual: https://drive.google.com/file/d/1FiXXV68WvPZ4ukyUXtY7PGIV2C8bpVkK/view?usp=sharing
Diagnostics start on page 32, see what fault code you are getting.
Consumer Error Mode (CEM)--->Entry into Consumer Error Mode
Consumer Error Mode allows the consumer to retrieve the fault codes to assist with diagnosis at the time the consumer calls for service to their machine. The consumer cannot delete any of the codes or run any components.
dfphoto2
los angeles
Jake one more question there is a passage in the manual about setting the control board to the correct model if someone changes the board and I did change it but I don't understand how I figure out the model to change the panel to the correct setting 1-2-3 I believe do you know?
Its the personality code, Look on page 44 of the service manual I posted above--->on your model its personality ID--->10
It tells you how to change it to 10.
MrGibbs
Minneapolis
Washer was fine for probably 8 months after I leveled it, now doing it again - exact model number is GTW485ASJ1WS.
Any ideas?
Possibly its a drain pump problem, because if its not draining fast enough it will never spin or spin properly.
When it drains the water how fast is it draining out the drain hose into your drain pipe? What I do is pull the drain hose up from the drainpipe and watch how fast the water flows out.
It should be coming out the drain hose extremely fast with lots of water pressure.
In a full tub of water, it should drain all the water out in 90 seconds or less, time it with a stopwatch.
MrGibbs
Minneapolis
Once it starts draining, the water is kicked out quickly (definitely within 90 sec or less per your question). Never had a problem with this.
Problem seems to be either going from wash > rinse cycle. Gets stuck at end of wash cycle after kicking out water, and just continues to agitate, then stops.
Or gets stuck in final spin cycle right after the spin cycle starts. Just agitates and never kicks into final drain/spin routine that normally starts within 30 seconds or so of spin cycle beginning. This happens from normal cycle, as well as if I put it on the drain/spin cycle specifically.
I've unplugged it and tried resetting the machine (open and close lid 6 times) and this sometimes works, sometimes doesn't. Mainly seems to work if I let it sit for a couple hours, then come back to it and put it on drain/spin cycle again.
Ok,
Here's your service manual: https://drive.google.com/file/d/1FiXXV68WvPZ4ukyUXtY7PGIV2C8bpVkK/view?usp=sharing
Page 32 is diagnostics, see what error code you get.
Looks like I already said that in post #2 in 2021, you didn't see that before?
MrGibbs
Minneapolis
Ok, I got it into Consumer Service Mode and these are the faults that reported out - 3,19,26,7,14,17,23,16,18.
After that I put it in Field Service mode and ran the Spin test (with a full load of wet clothes) and it ran fine, drained no problem.
Then I cleared all codes using field service test 16.
Any ideas on next steps?
After you cleared the error codes, did you run a run a cycle and see if it ran normal again? If not, get the new error code/codes.
