- GTW680BSJ2WS
- GE
- 1-5 years
I am working on a washer that is giving error codes 16 and 18 after a cycle. These error codes suggest something is wrong with the drain pump. I have tested the pump by filling the tank with the pressure test and the tank quickly empties when the drain pump comes on, but the pump will continue to run even though it looks like all the water has been evacuated. I have also removed the pump from the tank. I have inspected it, and the outlet hose for any obstructions and found nothing. There was a little water that was still at the bottom of the tub but not more than a cup or two as warned in any maintenance instructions I have found.
Will the pump need to be replaced in order to fix this unit even though I can hear pump and it works enough to almost clear the tank?
Is there any other troubleshooting step I should try to identify the situation
