maxwell.anita
- GTW680BSJ6WS
- GE
- 1-5 years
Less than two months ago my washer started on its on. I posted a thread with the details on July 16, 2021. We replaced the main board and got a surge protector for the outlet and it seemed to work fine until last week. I did a quick wash and hadn’t taken the clothes out but had lifted the lid. A couple hours later we here it turn on and try to start draining and wouldn’t turn off. Cancel kept flashing across the screen but we couldn’t get it to do anything else. I reached down and felt the clothes and they were still wet.
My husband (a heating and cooling repairman) finally had time to look at it tonight. He unplugged the maroon plug from the back of the board labeled J512 subwasher and noted that there was a green light that was flashing about 1 flash per second. We ran a drain and spin cycle and it seemed to work. So we tried a load on the active wear setting. Hubby noted that it only went to spin mode at the end of the cycle and once again got stuck in the drain function and wouldn’t go into a spin. He checked to make sure the pressure switch was clear and that didn’t help, so he finally unplugged the maroon plug again and now it is spinning out. The second load ran fine. Any thoughts on what is going on? If it is the board again, is there any warranty on the board we bought in mid July?
