gilesitis
- GTW750CSL1WS
- GE
- 1-5 years
Our washer has been flashing the 'H2O Supply' error code during every cycle. We were able to workaround that for a little bit by just starting the cycle again. Then after water began leaking into the tub (even when off) I went ahead and replaced the water valve. It actually got to the point where it would never progress pass the 'Sensing' stage.
While swapping out the valves, I cleaned out the supply lines (we have a lot of sediment), and reconnected everything. Fired up a cycle and looked like everything was working. Washer was filing and moving through the cycle, but when it had about 5 minutes or so left, it flashed the dreaded 'H2O supply' again!
I couldn't find hardly any troubleshooting documentation on the GTW750CSL1WS mode, so I referenced other GE manuals. However, thanks to this forum I was able to get into service test mode. We got a few error codes, some for being out of balance, and then code 8 for pressure loss or something along those lines. I then ran a pressure test #10 in service mode. I don't even think it ran correctly. LEDs were supposed to flash during the test, but they didn't. However I did notice the water kicked on, and that was it.
At this point, I am not sure where to look next for the issue. I am hopeful some awesome folks here can provide some guidance on where to look next!
I greatly appreciate any help at all.
