GE washer overloaded & banging on spin cycle. Removed everything, still banging
NC
WPRE6100G1WT
I overloaded my GE Profile top loader washing machine. It started banging to the point of knocking the front end off. I emptied machine & started spin cycle again. Still banging. "Held, pressed tub backward" & it calmed down. Let go, banging started again. Still empty. Belt seems tight & in tact. What can I look for to possibly repair?
I'd first check all the suspension straps to see if any are worn/cracked/broken.
It's always best to replace them all when one is bad.
Here is the suspension straps you can order here:
WH1X2727 Washer Tub Dampening Strap
Video Included in part link to access/replace them.
If your straps are fine, then your suspension rods have failed and will need to be replaced.
If yours are orange, they have changed them to green(these are the two for the front):
WH16X10057 Suspension Rod & Spring Assembly
Video Included in part link.
If yours are black, they have changed them to white(these are the two for the rear):
WH16X10141 Rod & Spring Asm
