GE Washer stacked combo model# GTUP270EM0WW not spinning
Dem29
Southern IL
GTUP270EM0WW
Washer won't go into spin? It has a error code that says its a overfill. You can clear the code but it just comes up again. In manual mode you can spin it from the computer and it will work. When you put it back into manual cycle. The machine will fill and agitate and when its ready to go into spin mode you can see the actuator move to the spin mode but doesn't do it. All it does is the drain pump runs constantly and will not run the motor to spin. The same error code will come up with overfill. The pressure tube is clear. I just don't what going on with this.
