FIXED GE washer top load GTWP1800D2WW will not agitate
Webctor
Chicago
GTWP1800D2WW
I have a washer GE
Stopped to agitate and spin
When I pull timer shifter starts to click, if push timer back, shifter is still clicking
On inverter board/motor 3 times flash
I replaced the motor, shifter stopped to click
Washer fills up with water and then nothing happen, then drain and spin is fine
I still have 3 times flash
I replaced control board/timer
Still the same
I replaced motor one more time
Still the same
3 times flash
Shifter some times clicking
Need your help guys
Sorry for my English
Shawn has a good webpage that explains this issue: HydroWave GE Washer Repair Guide
3 flashes - This is a software problem - Clear the code and if problem still exist replace the motor.
To clear the error code, turn the washer off. Then disconnect power for about 20 seconds. Next, reconnect power then open and close the lid five or more times within 12 seconds in the first 30 seconds of power-up.
Here's the motor/inverter for your model:
WH20X10093 Motor and Inverter Asm
So that fixed it?
Then either your getting faulty motors or you have a short in your wiring, check all your wiring for breaks in it.
Webctor
Chicago
What resistance supposed to be for shifter?
Problem is fixed
Voltage from outlet was 115v
When I connect washer, voltage 95v
When I turn on wash cycle, voltage 85v
Connected washer to another circuit breaker, got 120v, everything works
Thank you
Shawn has a misprint in his website, the shifter should be about 66 ohms, not 98 ohms.
