FIXED GE Washer wont wash/spin GTW680BSJ3WS Serial # FG165571G HELP!!
abick23
boiling springs PA
GTW680BSJ3WS
Washer wont enter wash or spin mode at all. Water drain pump works but basket will not spin. It does spin when you do a spin test. The codes are 16 and 18 which is basically drain pump clearing algorithm failed. I check all the hoses and they are all clear.
  • GTW HTW MTW No spin agitate or drain.pdf
abick23
boiling springs PA
I did this TSB and now the drum spins when you do a drain and spin cycle. Unfortunately now when you start a wash cycle it is endlessly stuck on the "sensing" cycle. Any ideas?
See if this pertains to your model:
  • GTW Service Flash-2.pdf
jhtoolman2000
Illinois
Hey Rick!
Thanks for reply. I meant to back on here. I fixed it this morning. I used the 1/16” drill bit and cleared out the chamber port flash. Also I noticed the tube was not connected to the port on the controller board either (it may have come off when I was dismantling the lid). Anyway, ran 4 loads now and so far so good. Couldn’t get past one load the past few days without the clothes soaking wet. Thanks for all the help! This forum is awesome!
~Jon
