GE Washer WTGN4250M1WS repeats drain, rinse, spin cycle over and over.
Craig C.
Dayton, KY
WGTN4250M1WS
I have a GTWN4250M1WS washer that repeats the rinse, drain and spin cycle over and over. I replaced the control board and that didn't fix it. When I put in service mode some test shows the spin led should be lit, but does not. Any thoughts? All cycles work fine until it gets to this cycle and never shuts off.
So, in the rinse cycle the water fills up the tub and agitates? Then drains and spins over and over?
Are you sure the water is not siphoning out, thus not filling the tub to agitate in rinse?
Pull your drain hose up from the drain stand to verify its not siphoning the water out as its filling in rinse.
