beatnick27
- WBVH5300K0WW
Having an issue with my GE washer completing cycles. If I choose any wash cycle, it will usually (though not always) dispense water + detergent and begin tumbling the load normally, but at some point it will stop, drain the water, and then the Start/Pause light will blink and the washer does not proceed. Initially, I thought it was only doing this during the transition to the Rinse cycle, but it just happened while the display still said Wash. If I run the Rinse and Spin cycle, it will dispense the Rinse water but doesn't tumble, and eventually stops as described above. If I run Drain and Spin cycle, it will spin normally and complete the cycle.
The issue seemed to first come up after an unbalanced load, and the washer seemed to have rattled itself into a spot the wasn't level. I've moved it back to a level spot, but the issue persists even with a normal load or no load. I entered service mode and received error codes E22 and E23. I emptied the pump drain - there was some debris in there, but I'm still having the same issue now that it's emptied. The 2 test modes that are recommended for these error codes, t08 and t09, are apparently not available on this model. I ran t05, 06, 10, and 11 and all completed normally.
Any thoughts would be greatly appreciated. Thanks.
