FIXED GE WBVH6260 E54 error
Anthony S
Otsego Michigan
WBVH6260
I ran in test mode and got E54 error code, replaced inverter and it's still not working and has the E54 error code again.
E54 error code says:
Power down (unplug) washer, wait 30 seconds and
retry - if reoccurs, replace inverter.
Here's the motor inverter for your model:
Motor Control Board WH12X10418
Anthony S
Otsego Michigan
Ok I put my multimeter on the red & blue at junction box and went into t10 mode and started test, I got no voltage when I ran it in t10, I went into normal mode then unplugged the washer, I checked resistance between the 2 yellow wires at the control panel for the motor and got 115 ohm of resistance. I haven't tested the pressure switch because now I think it's the control board, am I correct or could something else keep it from getting voltage??
Anthony S
Otsego Michigan
In the instructions I have it doesn't say unplug the ac plug then check the voltage between blue & red, so I unplugged then checked, I have a constant voltage of 18.5 volts at the red & blue wire at all times weather I run in t10-11 or 14 or no voltage at all when it's plugged back together then checked, I never have 120 volts ever though.
Sounds like the control board is bad then.
Here's the control board assembly for this model you can order:
GE WH12X10355 Control Board Assembly
If you purchase parts from our links here and you install them and it doesn't fix the problem, you have a 365 day full refund when you return them.
Ok sounds good, keep us posted.
Anthony S
Otsego Michigan
Just wanted to let you know I received my control board today, I finally have a working washer. I have a spare inverter now because it was the control board, guess I'm covered for a while on them if one goes bad. Thank you very much for your help, I couldn't have fixed it without you!!
Ok, sounds good, thats for the update.:)
