GE wine cooler PWR04FANBBS not cooling and does not react on the buttons
gsnake
West Vancouver
PWR04FANBBS
GE wine cooler PWR04FANBBS not cooling and does not react on the buttons. I moved into the new house and it has this wine cooler. The cooler is showing 8 C temperature and that is about it. It does not react on the keys pressing (I tried the reset, did not work). The compressor is not running either. I like the unit and hoping it could be fixed. What would be a good point to start troubleshooting?
thanks!
The part you need has been discontinued and is no longer available:
That part is a Samsung # DA41-00518A. While also discontinued, it might give the OP another part number to try to track down.
JFYI
gsnake
West Vancouver
thanks guys! wow.. I tried to google it too but could not find anything that would be available.. this part Samsung # DA41-00518A i found.. But could it also be the other board that is related to the keys? scared to purchase this one and there is no return on these parts..
Thanks bb!
LOL.....I meant Dan O. My bad
Try disconnecting and then reconnecting all the connectors on all the boards. I'll see if I can locate the wiring diagram. Most of the time the main board stops sending the low voltage to the control board. If you have a copy of your wiring diagram, post it here.
gsnake
West Vancouver
Disconnected all the boards and connected them back. the same as before - the display shows 8 and does not respond to anything.. :(
gsnake
West Vancouver
thanks.. before I get it how can I check if compressor is functional and Freon is there? just don't want to start spending money on it :) this came with the house I purchased so I don't know how long ago it stopped working..
bigbuck
From Planet Mars
I have the service manual.Gives more information.
  • 31-9099 GE PWR04FANBB PWR04FANBS Service Manual.pdf
