GE ZDIC150ZBBE Ice machine only makes one batch
cspackler
Ohio
ZDIC150ZBBE
Hi, moved into a new house that has a stand alone GE icemaker, ZDIC150ZBBE. It will make one batch of ice when you turn it on but then it runs and will not make additional ice. Water runs across the plate but does not seem to freeze. The unit makes thudding quite a bit which I believe means it is trying to make ice. Is there anything I should be checking? The unit made ice before I moved in, I ran a clean cycle and removed all of the ice and now it is having issues. Appreciate any help.
Brandon
Hi Brandon,
I haven't been able to locate the service manual for this model, hopefully another tech. or member that seen this issue happen before can shed some light on it for you.
