- AZ61H15DAB
- GE
- 1-5 years
We have a GE Zoneline AZ61H15DAB installed in a rental unit and, with it powered on, the compressor never stops. When the temperature is satisfied, the blower stops as it should, but the compressor keeps "rumbling" in the background. For now we just plug it in when it gets cold, and then unplug when it's warm enough. We have to set it high (78 degrees) so we are not constantly plugging and unplugging. The unit is only 5-1/2 years old and I really don't want to buy a new one yet. The heat pump and the resistance heat are working fine, but the compressor never turns off. Is there a simple solution that someone may have come across for this? Does something need to be reset? Is there an AUX mode setting that needs to bee turned on or off?
Gary
Gary
