GEW9250PW1 Whirlpool Dryer no power no lights suddenly.
Jim Saves
ga
GEW9250PW1
My dryer Whirlpool duet about 12 years old GEW9250PW1 was working fine the other day. I went to do laundry today and everything is dead. No power at all lighting up on dryer. I did not notice any dimming before it seemed ok. is it the interface ?
Hi Jim,
Yes, its possibly your user interface button/buttons/lights are shorted causing this issue.
Here's our main thread on this problem:
Here is the online repair manual for the Whirlpool Duet dryer: https://www.applianceblog.com/manuals/Duetdry.pdf
Page 4-4 shows you how to remove and replace the control panel touchpad assembly(User Interface).
Disconnect then reconnect the P3 and P4 connectors (UI ). Do that a couple times make sure its tight and try it. Also, check for DC voltage going to the UI at P3 and P4.
Here's the UI(user interface) for your model:
