GFE29HSDGSS GE Refrigerator Randomly Dispensing Water
pblaket
Oklahoma
GFE29HSDGSS
Hi all. Model No. GFE29HSDGSS GE fridge water dispenser will randomly run multiple times a day. So far the main control board has been replaced, the front control board has been replaced as well as the water inlet valves. The lines have been swapped to confirm it wasn't the ice maker filling with water, but it runs either way. I'm not sure what else to look at. Alternatively, if no other fix can be found does anyone know how to disable only the water dispenser while keeping both the top and bottom ice makers working? FYI the problem still persists when turning off the top or bottom ice makers as well. Any advice would be appreciated.
Ok, I located this thread started in 2018, we have become aware of the fix for it by another member:
For model number GFE29HSDGSS You would need to order these two parts below.
WR17X13200 Display Asm
WR55X11144 Pcb Asm Led Icon Ui
