FIXED GFMN100EL0WW GE dryer not running CLEAN FILTER FLASHING
leosar
canada
GFMN100EL0WW
HI EVERYBODY,
MY DRYER DOES'NT RUN.
I POWER IT ON, SELECT CYCLE PUSHED START IT DOES'NT RUN : CLEAN FILTER FLASHING FOR A WHILE.
THE SCREEN COUNT TIME(50-49-48----000)
CHECK THERMOSTAT, THERMISTORS, HI-LIMIT.DOOR SWITCH , BELT , AND BELT SWITCH...OK
PLEASE HELP
THANKS
Recheck your model number. Nothing comes up with that one. Read it from the tag on the machine.
Click here: Appliance Parts follow the link “How to find a model number”
leosar
canada
thanks for the reply.
i checked again ,the model is correct GFMN100EL0WW .
and this is the electric diagram for it.
Did you check the resistance of the two thermistors? Measure the voltage between the black wire and the white and the white wire and the orange wire in the 3 wire connector.
leosar
canada
thank you Rick.
so i checked the resistance of the thermistors :it is around 150 kohms eatch (temp around 60F in the basement).
also:
black wire+white wire=120 v
orange +white=120v
black+orange=238v
also i bypass the motor relay : orange +purple =the motor runs ,but if i press start it doesn't run
thanks
leosar
canada
thanks for the help.
is there any probability that the user interface could be defect?
is there a way to know?
thank you
