RandomFixStuff
- GFW450SPM1DG
- GE
- 1-5 years
Hi, folks!
Trying to run down a problem with my G.E. The cycle Pauses, the drain pump runs.... and runs... and runs. I have confirmed that it continues to run for at least 5 minutes AFTER the tub is empty. Yes, the pump IS running, and the water is evacuated correctly. No clogs.
After reading a bit onlne, and the service manual, I have replaced the water level sensor, and it did one cycle correctly, now I'm back to square one. I blew through the tube and it does not seem to be obstructed.
I found the service manual online, and tried the the test mode. On my unit it's Temp > Delay Wash, Temp > Delay Wash. When I do that, the display shows 002, and I can't get anything else out of it. No error codes.
I don't understand how to tell the machine to initiate the various test modes.
Can someone offer some pointers on the test modes?
At this point, I'm wondering if something is intermittenly clogging the sensor tube (a floating sock that escaped the inner tub, perhaps?) or if the brain is fried.
