- GFW490RPK0DG
- GE
- 1-5 years
About 3 months ago my 3 year old “high end” GE washer quit working altogether. I opened up the top and the 110v fuse on the main board was open. I replaced and it worked fine until last week. It was totally dead. I opened again and fuse was good but probing the board showed no low voltage DC anywhere. I guess the LV PS was toast. I ordered the PCB IMC ASM WH12X26034 and installed. Washer came to life and the drain pump came on and runs continuously even with the controls off.
I put it in service mode and checked for codes, none. Cleared EEPROM, no change. All of the other tests seem to work (except it can’t fill with water as drain pump is on all the time). The sensor read 45Hz. If I unplug the harness plug near the pump relay, it stops. It’s like the washer doesn’t know the pump is on. I thought maybe the pump relay on the board was stuck closed but after probing, it appears to be Normally Open like the one on the bad board.
If the relay supplies power to the pump, why would the machine not notice it was having the pump run all the time? Is the relay on the PCB an input for another relay down on the pump that could be stuck? Don’t want to waste anymore time or money on it if I am chasing a gremlin. Any thoughts?
