I have a GE front load washer # GFW510SCN0WW that runs through all cycles except draining water from the tub. Drain pump was replaced with a new one–problem still unresolved. Both hoses (from tub to pump and from pump to drain) are clear and unobstructed. Pressure tube and receptacle are also clear and unobstructed. Consumer Fault Code displays no errors, only blank “_ _”. Service Mode Test Codes 0 to 10 all pass. When running Code 12 (Drain pump) sequence, washer pauses, stops cycle, and turns off with no further codes or actions. Will check continuity on pump. New control board?
