- GFWN1100L0WW
- GE
- 1-5 years
We have a front load GE that just stopped going through it's full cycle. I have gone through all of the prescribed steps, but I'm still not sure which part to replace.
1. The resistance at the motor all checks out correctly.
2. I get an error code E54 which the manual describes as a communication error to the motor. The recommended fix seems to be replacing the inverter.
3. I tried the T10/T11 tests and it just beeps twice but does not initiate the test sequence. I do not get any voltage at the blue/red wires because the test sequence does not start.
4. I DO get 120 at the blue/red wires when the machine goes through it's regular startup and anytime the motor should turn in normal mode - which tells me the main controller is sending voltage (but the motor still doesn't turn).
#3 makes it seem like the main control board is bad, but #4 makes it seem like the inverter is bad. I don't know which to replace and both parts are very expensive. Anyone know of a way to narrow down the issue further?
Also, does anyone know which T1 to choose if I want to reset the main board? I don't see my model listed anywhere for this setup. Model# GFWN1100L0WW
