GH5184XPS5 Microwave Not Working
wpollock
California
GH5184XPS5
Suddenly stopped working.
Main power supply is good.
No readouts on display panel and interior light will not come on when door is opened.
I tested the in line fuse and it reads good according to my multimeter.
Any thoughts as to what I should check next? Could the problem be a door switch?
Looks good to me. Try it on the diode check function. 120 VAC at the control board and nothing works = bad control board.
