bobandsandy
- GHW9100LW1
- Whirlpool
- More than 10 years
Hello,
I am summarizing my memory of issues with my dad's (Bob) washer. He will likely add his info shortly if I am incorrect. They have a Whirlpool Duet appx 12 yrs old model GHW9100LW1. Initially it would stop mid cycle and give an err code of FH. Mom would hit cancel twice and unplug it. Wait about ten minutes and turn back on. It would finish the cycle. Started getting worse until she could not complete a load at all. Dad disconnect the hoses and cleaned gunk out of the hoses/screens. He replaced the incoming hoses and ordered a new washer inlet flow meter and a washer water inlet valve. The inlet valve has been installed, and the machine reassembled. The code then showed door locked (or something similar), but the door was not locked.
(This next part may not be helpful relevant to the fix, but we certainly need to understand potentially for later why some of our machine parts do not match the diagrams.) We did not install the washer inlet flow meter because it appears to be the wrong one. (After rubbing a pencil on the side of ours we can see what appears to be a part number but have found no matches for it.) We ordered and received WPW10110225 as we see on multiple parts diagrams online. This one will not plug into our wiring harness, and does not look the same in the pictures as ours does. Our wiring harness clip is also different. Pic attached. (The video still is from a Repairclinic video of replacing the inlet flow meter.) If you look at a side view of the WPW part you can clearly see the outer plug portion outside of the main part. If you look at the side view of our original part that portion is not there.
our washer above
part of repair clinic video
the part we ordered that does not fit
Thank you for your help!
Cheryl for Bob
our washer above
Cheryl for Bob
