GHW9300PW4 On WP Duet Can You Use Second Set Of Tub Spring Holes?
Quadsteer
New York
GHW9300PW4
There are 2 sets right next to each other, set they are in are pretty worn...not sure if it would unbalance or offset the tub badly. Also, do you use sealer on the tub gasket after bearing replacement, some videos show it some don't?
I really don't know if you can use those two set of tub spring holes, never tried it before myself, maybe another tech has and can let us know it that would work or not.:)
Here are the tub springs for your model:
W10135004 Spring
There is a video that shows you HOW TO replace the tub springs in the part link.
Here's the main tub gasket seal for your model:
WP8181673 Tub Gasket
There is also a video in the tub gasket part link too.:)
