GI0FSAXVY08 Whirlpool Refrigerator - Came home from X-Mas and fridge was out.
sagrimson
Mpls
GI0FSAXVY08
Came home and fridge wasn't working. Front display panel was blinking and I could hear a "clicking" sound coming from the fridge. Pulled electrical plug for 20+ min and plugged back in, can hear an initial beep, front display blinks, ice door flaps and clicking sound. This would continue to happen randomly, every few minutes or longer while plugged in. Nothing will stay on for more than seconds and now seems to stay completely dead, no lights, clicking or anything unless I unplug and re-plug back in.
The clicking appears to be coming from main board on back of fridge. Per previous threads I found, I tested voltage between J1-4 (red) and J1-8 (white) = 120 Volts AC Supply Voltage and zero. I also measure the voltage between J6-1 (blk/grn) and J6-2 (red/blk) and nothing. I presume to do this correctly I would unplug wire harness and put volt meter to pins while fridge is plugged into outlet? Appears to be a bad board from everything I have seen, does that seem to be accurate?
Yes, the main control board is the culprit.
Here's the part you need:
