GLD4560N10SS blinking clean light, nothing works
ApplianceFirst
Delaware
GLD4560N10SS
So have a blinking clean light, about 1 time per sec. Nothing was happening originally, changed the control board and ui board. Now I get this flashing, but only thing that seems to make any response is pressing the start button will beep. Holding it does nothing, all other buttons silent on press.
You checked BOTH door switches? if one or both are bad the dishwasher will not start. If the door switches are fine next check the door handle actuator.
Your model takes two door switches.
Here's another person that had a similar problem:
Here's the door switch for your model:
Interlock Switch WD21X10224
Watch this video to ohm test them: https://www.repairclinic.com/Repair...-Terminal-Switch-Testing-Repair-Repair-Clinic
Here's the door handle actuator for your model:
WD13X10045 Handle Actuator
There is a "HOW TO" video in the part link.
Here's the door switch spring for your model:
WD03X10026 Spring Plunger
Here's the door switch plunger for your model:
WD12X10271 Plunger Sw Interlock
