GLD4560V00SS GE Dishwasher - 3 lights flashing and beeping once every minute
Nabil2507
Oklahoma
GLD4560V00SS
My GLD4560V00SS dishwasher had a problem of 3 lights flashing and beeping once every minute, after reading here I end up buying control and display board and I install both them according the instructions sent with them, but now no lights at all, when plug it I heard one beep that’s all.
No lights and none of the button respond,
Any help ?
Look on the old control board for the CN4 connector (model select). Remove the connector from the old board and install it on the new board.
Nabil2507
Oklahoma
If you are talking about the model selector plug (resistor), I did transfer it from old to new but no luck, no lights at all.
All I hear is one beep when I plugged it back in
Check all the connections and pins in the connectors. See if you can exchange it for a replacement.
Nabil2507
Oklahoma
Now after I took all apart and put them back, it works once I closed the door but it did stop it didn’t finish the cycle, tried to start it again using start/test button but nothin happening,
2 lights on: Start and Heated Dry.
What’s the problem? any ideas?
You're suppose to check the switch before ordering a new one. You may not need a door switch.
