GLET1031CS0 Frigidaire Stackable washer emitting sewer gas odor, agitator seems to be loose also
Melsair
NC
GLET1031CS0
Frigidaire
I want to remove the agitator and tub to clean out everything, but the bolt is rounded off. Any ideas how to get it off. The agitator seems to be loose also, but I'm not sure how much play should be expected. Thoughts? Thanks
You may need to get a rounded off bolt remover, most hardware stores sell them.
I'd first check your drive block, Unscrew the agitator cap, then you will see the bolt that holds your agitator in, just remove it and the agitator will pull up, then you can see if the drive block is stripped on the transmission shaft.
Here's the drive block for your model:
Drive Block 134418700
Watch this video:
