Goldstar Microwave MVH1615WW magnetron getting very hot
jokken
NJ
MVH1615WW
LG
hi, i have a Goldstar Microwave MVH1615WW. Originally this unit was having the loud droning sound I am familiar with being a bad magentron. And I replaced the magnetron with a used one. It seems to work and heats water pretty well, but the magnetron is getting very hot and sometimes gives off a smell. I'm a little afraid of it, so I think im done fussing with it.
But I would love to know, should the magnetron get so hot that the ring between the magnets gets red hot and glowing?
The fan on this unit is very quiet and i wonder if it isn't spinning fast enough, and maybe not cooling the magnetron correctly (the original magnetron and this replacement one).
any advice would be great, thx!
Mag tubes go by the microwave wattage. They are not all the same. A 500 watt mag tube in a 1000 watt machine can potentially start a fire. A 1000 watt mag tube in a 500 watt microwave will take 3-5 times longer to cook if it works at all.
jokken
NJ
good point, i double checked the old and the new magnetrons. while neither say wattage/amperage, they both have the same model number. i think they are the same. LG Magnetron 6324W1A001L
jokken
NJ
thanks Rick. there is a cavity thermostat (thermal fuse) mounted next to the magnetron. can that be connected backwards? the "new" megnetron came with a "new" one but I was not able to figure out which connector/side was what.
