GS5SHAXNL00 Whirlpool Refrigerator icemaker not harvesting
jdoty
Texas
GS5SHAXNL00
I noticed the bin was empty, raised the icemaker white flap and there was a cube stuck in the fingers. Removed the cube, ice tray full of ice, but icemaker is not harvesting. Red LED is on solid when door is closed.
Is there a way to cycle the icemaker without using a jumper wire? I ask because the control module test holes are unreachable without physically removing the icemaker.
.... Is there a way to cycle the icemaker without using a jumper wire?
No, remove the ice maker. Tape the flapper back so you don't block the beam between the emitter and receiver and check for 120 VAC across holes "L" and "N"
If the voltage is correct, use a short piece of insulated wire and short holes "T and "H".
As soon as the harvest cycle starts, remove the wire. Remove the tape holding the flapper and the beam will be blocked. Finish reinstalling the ice maker then close the door.
