GS5SHAXNL00 Whirlpool Refrigerator - no power to ice maker
frabreeze
Montana
GS5SHAXNL00
I'm working on a whirlpool side by side model #GS5SHAXNL00, my ice maker quit so replaced it with a new one, it never did go to working, I tested the power coming in to the ice make on the L and N ports and no power, I then checked the continuity on the ice machine pig tail and all is good there. I manually tested the water solenoid and it sent water to the ice maker, any thoughts on why no power? is there another place to check for power? thanks.
You Checked the in-line fuse on the ice maker wire harness? If that fuse is blown you will never get power to the ice maker.
This is how:
Ohm the in-line thermal fuse, its located on the wiring harness to the ice maker. If that in-line thermal fuse is open, then you will never see any voltage to the ice maker.
It comes integrated with the ice maker wire harness, in case you need to order it:
WP2187467 Harness, Wiring
Its the black wire, ohm that black wire for continuity with a multimeter.
If that black wire shows continuity, then you must have a wire broken at the ice maker power source plug.
Ok, then I'd check for a broken wire to the ice maker power supply plug.
