GSC25C6EYY Water leaking out of the ice machine
Yvette Benner
Los Angeles
GSC25C6EYY
I have a problem with water overflowing from the ice machine into the ice tray and eventually flooding the kitchen floor in front of the fridge. It happened once last year, but the problem didn't reoccur until 3 weeks ago. Now it is happening regularly. I have the ice maker shut off, but would like to get to the root of the problem so that we can have ice again without the risk of flooding our kitchen.
This refrigerator is so fussy it causes me stress. LOL.
It sounds like the ice maker itself is the problem because it tells the water inlet valve how much water to fill it with, so its malfunctioning and telling the water inlet valve to stay on too long, thus too much water and flood.
Here's the ice maker for your model you can order:
WPW10251076 Icemaker
Yes,
To access the ice maker in your refrigerator you would take the ice bin out and remove the 2 screws that are on either side. Lift up on the casing and lift the casing off. Once off there will be 2 screws holding the ice maker bracket in place. Unplug harness and remove the screws and lift ice maker out.
