I hope tagging on to this thread is OK but here goes. I had ice maker problems at the end of last year, and thanks to this forum I discovered the broken wires at the bottom of the door. I repaired/replaced all of the wires and the problem was solved.
Now, six months later, the NO ICE problem popped up again. The first thing I looked for was to see if the wires had again broken. They were fine, no problem with the wires, so next I removed the ice bucket and the cover to gain access to the ice maker.
Upon inspection I noticed that on the left side top of the ice maker, several cubes were somehow pushed up and fused together and blocking the mechanism from rotating. Good news..! I just removed the out of place cubes and I'm back in business making ice.
A few days later it stopped again, so I inspected the ice maker and discovered the same thing, a few cubes frozen together above the ice maker and stopping the rotation, this time on the far right side of the ice maker.
I'm wondering if the paddles that turn to push the ice into the bucket are not rotating, so the ice stays on top rather than continuing on and dropping into the bucket? It hasn't happened all the way across... yet, so not sure if it could be the paddles?? If it does turn out to be the paddles, I assume that means a new ice maker is in my future?
I fixed it again this morning and I'm now waiting to see what happens, but I suspect it will continue to do the same thing since it has done it twice. Any thoughts on this particular problem?
Thank you again for the help, you're saving us all lots of $$$$$$$$$$
