broastedturkey2017
- GSE25HGHBHBB
On this GSE25HGHBHBB refrigerator, about 3 years old, I have changed the water filter every 6 months as required. After the latest filter change, the water began coming out slowly in the following fashion: when depressing the water dispenser button, the water comes out slower than on the last filter, and as time passes with the dispenser button pressed, it comes out slower and slower.
I tried replacing the filter with a bypass cap, and found that no water came out of the dispenser at all, and instead a loud rattling noise was heard in the back of the refrigerator, so I put the filter back on.
I see that some postings have suggested the following (1) frozen dispensing tube, (2) broken input valve in the back panel of the refrigerator, (3) broken filter head assembly, (4) changes in the design of the MWF filter affecting its connection with the filter head assembly, (5) low water pressure, (6) defective wall spigot, etc.
What steps should I take to figure out whether, for example, the input valve is broken or the filter head assembly is broken? Why does no water come out when I install a bypass cap? I would have thought that it would make the water come out easily because it doesn't have to go through a filter.
Any advice would be appreciated.
