GSH25JSRFSS Refrigerator and freezer won’t cool
TimP
Austin, TX
GSH25JSRFSS
Interior lights work but control panel led lights and water, ice and light do not.
After unplug/plugin there is a slight humming noise at the top of the freezer section and a faint led pulsing led light on the control panel for the chosen function (ie: water, cubed or crushed). After a few minutes the noise and the pulsing light both stop.
No other noises and won’t cool.
Thanks in advance for any suggestions.
Hi Tim,
You'll need a multimeter to check the voltage to the compressor from the motherboard itself.
Remove the cover over the back of the motherboard and measure the voltage between J8 and J7-9, you should get 120 volts when the compressor should be running. If not, then your motherboard is the culprit.
(click to enlarge)
Here's the motherboard for your model you can order:
Main Control Board WR55X10942P
You get $55 CASH BACK When you return your old one.
Ok Tim,
Yes, then the new motherboard will fix it.
I went on a service call Saturday in Quartzsite, AZ on a GE side by side not cooling, same thing no voltage between J8 and J7-9, so I ordered a new motherboard as well.:)
